how to see a linux serial port from a USB
Moderator: djandruczyk
Postby bi-andrea » Fri Aug 17, 2012 1:26 am
detection system is to engage in something like a cable modem, another computer, the control unit, in short, everything to make it connected.
So this is the procedure without cable
Code: Select all
lusb
Code: Select all
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
cable and put something at the other end
Code: Select all
lsusb
Code: Select all
Bus 001 Device 023: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Code: Select all
modprobe usbserial vendor=067b product=2303
Code: Select all
modprobe pl2303
Code: Select all
dmesg | grep ttyUSB*
Code: Select all
[  779.498926] usb 1-1: pl2303 converter now attached to ttyUSB0
[  784.592444] pl2303 ttyUSB0: pl2303 converter now disconnected from ttyUSB0
[  786.216004] usb 1-1: pl2303 converter now attached to ttyUSB0
[  787.568442] pl2303 ttyUSB0: pl2303 converter now disconnected from ttyUSB0
[  788.448004] usb 1-1: pl2303 converter now attached to ttyUSB0
to have the module loaded at next boot of the PC type
Code: Select all
depmod
performed with Gentoo, Debian, Ubuntu
bi-andrea
Return to Megatunix (obsolete)
