Support for microsquirt (MSII v3.77)
Moderator: djandruczyk
Does megatunix support microsquirt (MSII v3.77)? I'm running 0.9.23. Thanks/
1981 Volkswagen Vanagon Westfalia - air-cooled Type4 1970cc CV (hydraulic lifters, 42x36 valves, stock cam, microSquirt FI with wasted spark ignition)
Re: Support for microsquirt (MSII v3.77)
I think it will work if you use the more common MS2/Extra firmware on your Microsquirt.
Is it more common to run MS2/Extra firmware? I couldnt find any documentation showing the difference in firmware.
From what I understand about 85% of users are on MS2/Extra.
There's an old feature comparison table here: http://www.msextra.com/doc/ms2extra/MS2 ... m#features but it is out dated for MS2/BG and MS2/Extra.
What version of MegaTunix do you need to drive the 3.2.4 MS2/Extra firmware?
- MS/Extra Guru
luftvagon wrote:What version of MegaTunix do you need to drive the 3.2.4 MS2/Extra firmware?
For now, you need to be using a development version from Git. What OS are you on? I may be able to make you a package for testing purposes.
David J. Andruczyk
I'm on Ubuntu 12.10.
- MS/Extra Guru
build it from git via the installing on Ubuntu thread.luftvagon wrote:I'm on Ubuntu 12.10.
David J. Andruczyk
