File format general
Moderator: djandruczyk
File format general
Postby foreverska » Thu Nov 13, 2014 7:24 pm
Hi forum,
I like the Megatunix software and I'm writing some software that parses and uses some of the file formats created by this software.
Tonight I'm working with the .vex in particular. This format seems a bit verbose at times but it is very human legible so I can't fault it too much. But I want to draw the line between verbosity and feature:
Is it reasonable to assume the indexes will be in order top to bottom and left to right?
Is there a reason for the table to ever have more or less rows and/or columns than indexes? It doesn't make sense logically to allow it but I wanted to know if I could count on this.
All "fields" in the file have a width of 3 characters except counts for index lists (VE Table RPM Range [ 8]). Does this not bug your OCD?
foreverska
Re: File format general
Postby djandruczyk » Fri Nov 14, 2014 8:49 am
foreverska wrote:Hi forum,
VEX is not my format, it came from Megatune (now defunct AFAIK) and mirrored its output including the whitespace. Megatunix just implements the format as a way to transfer 2D tables (VE/Spark/AFR/ etc) to other people. The indexes should be as you describe, and no, the table and indexes MUST match in dimension otherwise it's an error (at least in MTX),
Personally at this point I'd prefer something in yaml (more readable than json) which is also human readable but non-proprietary and readable by any yaml parser.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby foreverska » Sun Nov 16, 2014 12:53 am
I like VEX but it fits MS like a glove
If I wrote it, would you allow a second export format? Something quick and dirty to parse that allows for more flexibiliy, I'm thinking csv.
Is there a reference for the .ecu file format?
foreverska
Postby jsmcortina » Sun Nov 16, 2014 6:03 am
foreverska wrote:If I wrote it, would you allow a second export format?
Have you looked at the MSQ file format that is most widely used with Megasquirt ?
Postby foreverska » Sun Nov 16, 2014 7:11 am
HA! Trying to get me to do something the community wants.
The FAQ makes it sound pretty silly but I'll look at it.
foreverska
Postby foreverska » Sun Nov 16, 2014 11:50 am
Why is there zero standardization between MS versions in the MSQ file? Anything past MS1 I can't make heads or tales of. Even the MS1 files are a bit silly in their order IMO but I at least could Identify tables and their corresponding indexes. At any rate I'm more concerned with the export of a single table, MSQ doesn't seem like the way to do that. I could write support for .table.
foreverska
Postby jsmcortina » Sun Nov 16, 2014 12:40 pm
Not sure I understand your question? MS1 is obsolete now anyway.
Postby foreverska » Sun Nov 16, 2014 1:15 pm
If you look at an MSQ file from MS1, MS2 and MS3 none of the data is in the same place or particularly is named the same thing. I think some of it may come from differences between Tunerstudio, Tuner Studio MS Lite and Megatune. They all seem to be allowed to name tables whatever they feel like (ie veBin vs veTable) and I haven't been able to identify a pattern for which indexes definitely go to what tables and I have a feeling their "name" varies between versions. I don't want to have to teach a parser the English language just to pull a VE table or two.
I'll write a parser when I can count on a singular standard to be used for all MSQ files. Until then, I can write a .table import/export and I would prefer if we could add a skinnier, much quicker to parse CSV standard.
foreverska
Postby jsmcortina » Sun Nov 16, 2014 1:20 pm
It isn't really related to the tuning software used. The firmware supplied "ini" file defines what all of the fields are called. That's what Megatune, TunerStudio and MSdroid (and others?) use. It is unfortunate that Megatunix has never used the ini and MSQ files for cross compatability.
Postby foreverska » Sun Nov 16, 2014 2:05 pm
I do see that now that you mention it. I'm not the man to write that support.
I'm willing to write .table support if the community cares.
foreverska
Postby djandruczyk » Sun Nov 16, 2014 2:55 pm
jsmcortina wrote:It isn't really related to the tuning software used. The firmware supplied "ini" file defines what all of the fields are called. That's what Megatune, TunerStudio and MSdroid (and others?) use. It is unfortunate that Megatunix has never used the ini and MSQ files for cross compatability.
The problem with an MSQ AFAIK is that you cannot just import "Table X" from it, IGNORING everything else..
Mtx supports individual/all table import/export via the VEX file format (its an ugly format that is not really robust, but it does work. Mtx also does a yaml import/export (tables only) but for a different ECU type (not MS). I didn't implement that for MS as no other MS tuning product that I'm aware of used that format, so I didn't want to create a completing "standard" for passing tables around, as it just adds work and confusion for all.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Postby racingmini_mtl » Sun Nov 16, 2014 2:59 pm
djandruczyk wrote:The problem with an MSQ AFAIK is that you cannot just import "Table X" from it, IGNORING everything else..
TunerStudio does it.
racingmini_mtl
Postby djandruczyk » Mon Nov 17, 2014 9:10 am
It didn't used to... I don't use TS due to it's licensing terms and costs.
David J. Andruczyk
djandruczyk
MS/Extra Guru
Return to Megatunix (obsolete)
