New Drawings for the Nippondenso CAS
Postby joeyg1973 » Mon Feb 04, 2008 9:54 pm
So I wanted to squeeze in all the components of the second VR conditioner circuit onto the MS2v3.0 boards proto area. I wound up redrawing the schematic and then using a PCB layout program to figure out what the traces would be. This is the first time I have done anything like this but the results wound up to be better than I thought. I intend to make my traces using a "Circuit Writer" pen. You can find it here http://store.caig.com/s.nl/it.A/id.1770/.f?sc=2&category=174
Anyway everything in red is the traces and the green line is an external wire. Normally these are the top (red) and bottom (green) of the circuit board. I figured I might as well let someone else use this rather than have them have to figure it out themselves.
Believe it or not I figured out all of this out first on graph paper, then I moved on to the computer to double check what I had done. I got it right on the first try. Yes I am not being humble as I am d*** impressed with what I did. :)
MS2Extra Second VR Input Circuit.jpg (79.8 KiB) Viewed 560 times
MS2Extra Second VR Input Circuit - Component_Silkscreen.jpg (56.56 KiB) Viewed 562 times
MS2Extra Second VR Input Circuit - Trace + Ext. Wire.jpg (54.87 KiB) Viewed 555 times
joeyg1973
Schematic
Postby joeyg1973 » Mon Feb 04, 2008 9:56 pm
Couldn't fit the schematic in the last document.
MS2Extra 2nd vr input.jpg (127.13 KiB) Viewed 556 times
joeyg1973
Re: New Drawings for the Nippondenso CAS
Postby devojet » Tue May 13, 2008 4:24 am
Those drawings should come in handy. :D
Have you built a circuit using those diagrams? Have you tried out that Pen, did it work?
Cheers
Daniel
Building a 26 chev Hot rod with 1uzfe, MS2extra + James transmission control firmware.
EF falcon turbo MS2extra
Hilux 22R MS2 (mates car)
devojet
Postby joeyg1973 » Wed Jul 02, 2008 9:09 pm
devojet wrote:Those drawings should come in handy. :D
Cheers
Daniel
The pen didn't work. The area is too small. If the pen had a small fine ball point I think it would have worked, but it actually just has a stick valve at the tip that when you push it down it lets out a bit of ink. It isn't fine at all... it isn't that accurate either. What I did wind up doing was using the leads off of the resistors and caps to solder the circuit together. I tested the connectivity of everything and then coated liberally with red insulating varnish. It's not pretty but it does work. Take a look at the final result.
joeyg1973
Postby joeyg1973 » Wed Jul 02, 2008 9:10 pm
joeyg1973
Users browsing this forum: JonE30 and 0 guests
cron
