Hi all,
I've down loaded the TS Manual date 2014-12-01 via these forums and on page 267 point 17.12 Inj/Spk Disabling Test Mode this is different to TS MS v2.6.04. I want to use this option of being able to turn off an individual coil or injector to see if it makes a difference, but when in TS (with my motor running or not) I can't get this option.
Am I doing something wrong. Also I have MS3x.
http://www.msextra.com/doc/pdf/Megasqui ... ce-1.3.pdf
Hope this made sense.
Thanks, Kev
TS Manual different to EFI Analytics TS
Re: TS Manual different to EFI Analytics TS
im guessing you have an older version of the firmware that does not have that feature you need the 1.3.x fw
Thanks for replying grom_e30. With TS connected to my ECU is says at the top of screen - MS3 release 1.2.0
So I assume what you are saying is right. Is this something I can plug in an upgrade to a later version or the actual internal boards workings of the ECU. Sorry if this is a very newbie question, but that's what I am
Cheers, Kev
Cheers, Kev
Look in the setting up manual: http://www.msextra.com/doc/index.html#ms3. There's a section on firmware upgrade.
Thanks Jean, just need to try and understand the direction now from MS3 manual.
As I've mentioned in other posts, I can build cars, engines etc but when it comes to electronics I have no f***en idea
Cheers, Kev
Cheers, Kev
