Error Message
Error Message
Very new to all of this, and already stumped.
I keep getting this error message and can not figure out what I'm doing wrong, or how to fix my problem.
I'm allowing Tuner Studio to detect my ECU and choosing the option it provides me, but within a few minutes of connecting this error will pop up.
What am I missing?
What am I missing?
Re: Error Message
What kind of connection are you using?
In the picture it appears TS is getting nothing for a signature.
Re: Error Message
I have a 9 pin serial out of the ecu connected to a cable which is connected to a converter that plugs into my usb port on a lenovo.
All but the lenovo were purchased from diyautotune.com
Re: Error Message
Is this consistent or sporadic?
Are you using the thing USB cable between the adapter and the laptop, or plugging the adapter straight into the laptop?
Re: Error Message
Its quite consistent. I've tried using the thin USB cable as well as a 9 pin serial cable and get the error with both.
Re: Error Message
That is probably good and a sign it is not a noise issue.
Can you capture a COMM Debug log.
- Close TS
- Delete TunerStudioAppDebug.txt
- Start TS
- Turn on Comm Debug under the Communications menu
- Open your project, let it try to connect.
- When you get the error message, close it and close TS.
Post / Send your TunerStudioAppDebug.txt
That will make it easier to see what is going on.
- Close TS
- Start TS
Re: Error Message
Yes i can and will definitely do that. Thanks in advance.
It may be a day or two before I'm able to get back out to the garage but I will post what i find as soon as i can.
Re: Error Message
I was finally able to get back to the garage. I followed the directions you posted and attached is my debug.txt file
Re: Error Message
2 Things:
Have you tried the stable TS? Does it do it?
In your Comm Debug, it appears TS never did get a valid response to the signature request, I can figure out how it could do that, especially consistently.
So would like to see your project.
Can you send / post a Project Backup?
From the main Menu:
Vehicle Projects --> Create Project backup
From the main Menu:
Re: Error Message
Sorry to be such a newbie, but where do i get the stable TS?
I'll post a project backup tomorrow or Saturday.
Thanks for the help, I really appreciate it.
Re: Error Message
Re: Error Message
Having trouble trying to attach my project backup. Even when zipped the file is too big. I've attached my msq in case that will help.
Re: Error Message
You can send it to support <at> efianalytics. com
But, try the 3.0 version 1st, I think I found a way to make this happen in the beta and that was resolved.
Re: Error Message
I downloaded the 3.0 version last night and will give it a shot tomorrow.
I will also send my project file to the above address tomorrow afternoon.
Every time I use Auto Tune my car gets more fun to drive, thanks again for all that you do.
