Did first startup last night. Started on first crank. BUT....
The IAC is not set up right. Idle speed and mixture oscillated up and down. I finally set it to 15 minute time out and it stabilized after time out but was still idling much too fast, 1200 rpm.
Searching the forums, I see many references to setting the IAC to home but I cannot find anything like that in the tabs on Tuner Studio. I also see stuff on testing the IAC but cannot find that tab either.
Thanks in advance,
Craig
Setup:
Holley Terminator TBI
Mopar 5.2L Magnum
Timing control: stock distributor, stock electronic ignition.
Fuel control: Megasquirt 2 using Tuner Studio V3.0.01 with V2.92 code
Not able to load a file due to city firewall block
IAC Stepper
Re: IAC Stepper
The B&G V2.92 code does not have an IAC test function; you'll need to switch to MS2/Extra to get this.
Re: IAC Stepper
Thank you, downloaded the firmware, will install tonight.
Craig
Craig
