Feature Discussion/Suggestion: VEAL Auto-Smooth
Postby 5.0Thunder » Fri May 19, 2017 11:43 am
As we utilize the VEAL tool during tuning, the map generated can typically be peaky. After every tuning session I go inside and smooth things out manually based on what the engine is wanting in certain areas and if those areas were swept a lot during the session. Would it be wise to incorporate auto-smoothing into the VEAL feature that factors in hit-counts, interpolations between cells, etc.?
I'm about to have some load bearing dyno time where I want to experiment with using VEAL while targeting single cells and the auto-smoothing feature would be handy here. I think i'd basically be able to just let the engine run in each cell and not really touch anything but the "save" buttons.
1. 1990 Mustang: MS2v3.57, 306ci, 72mm turbo, 80lb inj, stock TFI ignition, 6AL, World heads, TFS1 cam, GT40 intake, & AOD
2. 1987 Mustang: MS2v3.57, direct coil control, MSD VR Dizzy, SBE, Weiand 174,190cc heads, F303, & TBI above blower with 4 160ln inj
5.0Thunder
Re: Feature Discussion/Suggestion: VEAL Auto-Smooth
Postby rukavina » Sat May 20, 2017 10:51 am
I also have a suggestion.... with Ms you can toggle outputs on and off to test. I don't know of that function on this board. I was able to test the controller I just built by faking a vss signal and running it thru it's paces but it would have been nice to just turn things on and off while on the bench...
4wheel drive 454 vortec on ms2 w/gpio for 4l80e Trans control
rukavina
Postby 5.0Thunder » Thu May 25, 2017 9:39 am
^^ May be better to post a new thread since that's a different feature.
5.0Thunder
Postby 5.0Thunder » Sat Jun 10, 2017 12:12 pm
Bump!
5.0Thunder
Postby 5.0Thunder » Tue Jun 20, 2017 5:51 am
5.0Thunder
Postby 5.0Thunder » Mon Jun 26, 2017 11:49 am
bump
5.0Thunder
Postby sschutte » Thu Jun 29, 2017 6:50 am
Feature request received. Please give us a week to review and get back to you.
Schutte
sschutte
Return to Tuner Studio
cron
