ms2 with mustang 5.0 and small blower
ok my car is up and running well point a to point b, I wanna use the auto tune feature , so what do I have to do? first off is this an extra charge? second I don't wanna loose my tune if something goes south so can anyone tell me the basics I am all new to it
Re: ms2 with mustang 5.0 and small blower
Auto Tune is only in the registered editions of TS.
Once you have it, Save your tune under the file menu:
File --> Save Tune As
Then you will have a tune to restore if you should need to for any reason.
Switch the the Tune Analyze Live! tab.
Click "Start Auto Tune"
Go for Drive.
Go for Drive.
ok I have a registered addition so it should be there then I guess, I will take a look later
Remember autotune will only be as good as your AFR and timing tables are. Meaning if you set your idle to 12:1 AFR or any other questionable settings autotune will just tune to your settings which may make the car run bad.
MS-III 3.0, MS3x
65 Cobra Daytona FFR, Terminator 4.6 4v, TKO 600
