over run fuel cut menu
Postby lotus23C » Thu Jan 11, 2018 11:13 pm
Hi
After changing MS2extra firmware to the latest, I cannot access the over run fuel cut menu, it just won't open using a win 8.1 tablet. I have put the MSQ on my home PC and it opens up fine. Anyone else found this?
thanks
Currently Lotus 23C replica Audi 1.8T MS 2 v3 Sequential COP and ignition.
Lotus 7 replica 4age 20V blacktop MS2 v3
lotus23C
Re: over run fuel cut menu
Postby sschutte » Fri Jan 12, 2018 5:55 am
This is odd, shouldn't be anything special with that dialog.
Please attach your MSQ file. This helps us get as close to your setup as possible making it easier to reproduce/troubleshoot the reported behavior.
What version of windows is on your home PC?
What version is your TunerStudio tablet vs PC?
Has the tablet been connected to a external monitor? (could the dialog be popping up outside the normal desktop area)
P.S.I just loaded ms2extra-release-3.4.2 firmware with default firmware tune on our bench MS2. The Over-run fuel cut menu came up just fine on my Windows 10 laptop running TunerStudio 3.0.28 (stable) and 3.0.50.40 (beta)
I will see if I can track down a Win8.1 PC that hasn't been upgraded to Win10..
sschutte
Postby LT401Vette » Fri Jan 12, 2018 6:59 am
Are you using the Beta TS?
There was an issue in recent betas where it would not display some Curve Graphs, this was fixed in 3.0.50.40 just last week..
If on the beta do a check for updates under the help menu.
Postby lotus23C » Fri Jan 12, 2018 2:18 pm
sschutte wrote:This is odd, shouldn't be anything special with that dialog.
Thanks MSQ attached.
The attachment 20v CurrentTune.msq is no longer available
Win 8.1 on tablet
Win 10 on PC
Tablet TS version:3.0.28
Firmware freshly downloaded: 3.4.2
I have rebooted the tablet a few times with no difference, the menu features above and below over run still work.
Ironically the issue I am having with my tune is over run fuel cut - but cannot access it :cry:
thanks for your help
20v CurrentTune.msq
(119.01 KiB) Downloaded 3 times
lotus23C
Postby turbo conversion » Sat Jan 13, 2018 1:28 pm
I looked at your msq and over run fuel cut is there and opened for me :?
David
turbo conversion
Postby kjones6039 » Sat Jan 13, 2018 2:35 pm
turbo conversion wrote:I looked at your msq and over run fuel cut is there and opened for me :?
David
Yep........ Worked for me too!
MS2 v3 w/extra 3.4.2 Release
kjones6039
Postby lotus23C » Sat Jan 13, 2018 5:31 pm
Yea, works on my home PC and had to change the fuel cut settings by sending the file to that and then send back to tablet. I suppose the version on my tablet could be, for some reason, corrupt.
lotus23C
Return to Tuner Studio
