PWM duty cycle gauge missing feature?
SwedCharger-67
Post by SwedCharger-67 »
I've designed my own PWM power electronics for speed control of a cooling pump. I would like to have a gauge showing the duty cycle driving the pump i.e. 0% at no pump and 100% at full pump.
Unfortunately my electronics is inverting the PWM signal (generic PWM output B connected to Nitrous 1 pin) and TS gauge is showing 100% at no pump and 0% at full pump.
I don't seem to find a way to swap it around, is there a way?
MS3X FW 1.5.1, regged TS v3.0.28 Linux-version.
Martin, Sweden
Mopar 512 cui, 8.4 liters, high compression, fuel E85, full sequential control by MS3X, burning rubber just blipping the throttle... :D
Re: PWM duty cycle gauge missing feature?
Post by LT401Vette »
Create a new OutputChannel that inverts it
[OutptuChannels]
invertedDutyCycle = { 100 - yourCurrentChannel }
Then assign your gauge to that OutptuChannel.
You can make the OutputChannel in the TuenrStudio MS Ultra Channel Editor, or edit/add your custom.ini file.
SwedCharger-67
Thanks a lot Phil!
That did the trick nicely! Impressive flexibility and excellent software engineering in the TunerStudio! :D
Martin, Sweden
