I can understand this would be low on the priority list, but I really would like to see a simple (one-level) Undo added into the Designer Mode.
There are hardly much more annoying things then accidently deleting a tediously designed multi-gauge cluster, and not being able to bring it back with a simple CTRL-Z.
Don't ask me how I know!
Feature Request: CTRL-Z in TS Designer Mode
Re: Feature Request: CTRL-Z in TS Designer Mode
I've been there myself. I would like to see a CTRL Z myself. Isn't trivial to implement though. Hopefully things will free up a little soon to get that in there.
a Copy/Paste function across tabs would be nice too. After I accidentally deleted a number of items today, I wanted to 'copy' them from another tab but there was no such thing.
Although I thought I had seen a copy-function once before.
Or maybe something like CTRL+ALT and dragging an existing button/gauge item, would create an identical copy of the item, so you just have to change the properties.
You can copy and paste from one dash to another.
Both dashes have to be in designer mode, but it shouldn't be a problem to copy on one dash and paste on another.
