After fighting with java to get a version installed that didn't give blank windows with java files, I finally managed to get TunerStudio windows to show it contents.
But, when opening the tune, it simply didn't get loaded and TunerStudio appeared to be hanging at the 'opening project'. But even though the screen was grayed darker, all the menu-items remained functioning.
The same setup and tune works fine on my MacPro and a Windows tablet.
Is there anything additional that needs to be installed with java to prevent this error perhaps?
Or is "libjnidispatch.so" to be put somewhere (else). I haven't checked yet if this file is located on the disc already somewhere).
TS Debug-file below:
Code: Select all
Starting on odroid
TunerStudio 3.0.28 started on Sun Feb 04 02:08:59 CET 2018
JRE 1.8.0_161, Linux 4.14.15-103, arm
java.library.path=lib
TunerStudioMS.jar
Look:Metal, ClassName:'javax.swing.plaf.metal.MetalLookAndFeel'
Look:Nimbus, ClassName:'javax.swing.plaf.nimbus.NimbusLookAndFeel'
Look:CDE/Motif, ClassName:'com.sun.java.swing.plaf.motif.MotifLookAndFeel'
Look:GTK+, ClassName:'com.sun.java.swing.plaf.gtk.GTKLookAndFeel'
Look:Night Shade, ClassName:'de.muntjak.tinylookandfeel.TinyLookAndFeel'
Setting Look & Feel to:javax.swing.plaf.metal.MetalLookAndFeel
ScrollBar.width
2/4/18 2:09:00 AM :Debug: no update:defaultFont
2/4/18 2:09:04 AM :Info: Loading Language Content.
2/4/18 2:09:04 AM :Info: Initializing File Dialogs.
2/4/18 2:09:04 AM :Debug: Command Non-VolatileBytes for F resolved to: x46 F
2/4/18 2:09:04 AM :Debug: Command Non-VolatileBytes for I resolved to: x49 I
2/4/18 2:09:04 AM :Debug: Command Non-VolatileBytes for f resolved to: x66 f
2/4/18 2:09:04 AM :Info: Initializing Plugin Services.
2/4/18 2:09:04 AM :Info: Loading Plugins.
2/4/18 2:09:04 AM :Info: Initializing Help.
2/4/18 2:09:04 AM :Info: Initializing Edition Features.
2/4/18 2:09:04 AM :Info: Initializing App Events.
2/4/18 2:09:04 AM :Debug: App Name:TunerStudio, appEdition:MS Ultra
2/4/18 2:09:04 AM :Info: Initializing Log Viewer Components.
2/4/18 2:09:04 AM :Info: Initializing User Interface
2/4/18 2:09:04 AM :Warning: Unable to set Main cluster for title:
2/4/18 2:09:06 AM :Info: Loading Font list.
2/4/18 2:09:06 AM :Debug: Time to retreive font name list: 16 ms.
2/4/18 2:09:06 AM :Info: Initializing UI Components.
2/4/18 2:09:06 AM :Info: Ready
2/4/18 2:09:06 AM :Info: Error Sorting Dialog: column beyond range of TableModel
MS Ultramain: No check, last update check=Wed Jan 31 21:55:58 CET 2018
MS Ultraad: No check, last update check=Wed Jan 31 21:56:01 CET 2018
2/4/18 2:09:12 AM :Debug: Directory Changed:
Old:/home/odroid
New:/home/odroid/Downloads
2/4/18 2:09:16 AM :Debug: File Changed:
Old:null
New:/home/odroid/Downloads/1973DodgeDart
2/4/18 2:09:16 AM :Info: Opening Project ...
2/4/18 2:09:16 AM :Debug: Opening project: /home/odroid/Downloads/1973DodgeDart
2/4/18 2:09:16 AM :Debug: Reading translation file as plain text
2/4/18 2:09:16 AM :Debug: EventTrigger Data log Reset. expression: AppEvent.dataLoggingActive == 0
2/4/18 2:09:16 AM :Debug: EventTrigger Stop Data log Reset. expression: AppEvent.dataLoggingActive != 0
2/4/18 2:09:17 AM :Info: Supported iniSpecVersion=3.51
2/4/18 2:09:17 AM :Debug: Filtered ConfigurationOptionGroup in 347ms.
2/4/18 2:09:17 AM :Info: Read file canPcVariables.ini: 1.730031ms
2/4/18 2:09:17 AM :Info: Filtered ini: 0.202332ms
2/4/18 2:09:17 AM :Info: No iniVersion defined
2/4/18 2:09:17 AM :Info: Loading Trigger Wheels
2/4/18 2:09:17 AM :Info: Loaded All known ini sections
2/4/18 2:09:17 AM :Info: Parsed and validated ini "canPcVariables.ini" in : 46ms.
2/4/18 2:09:17 AM :Info: Read file mainController.ini: 44.0442ms
2/4/18 2:09:17 AM :Info: Filtered ini: 70.22646ms
2/4/18 2:09:17 AM :Debug: ini signature: MS3 Format 0565.11
2/4/18 2:09:17 AM :Info: Loading Depricated ini section [UserDefined], use [UiDialogs]
2/4/18 2:09:18 AM :Info: Loaded All known ini sections
2/4/18 2:09:18 AM :Info: Parsed and validated ini "mainController.ini" in : 969ms.
2/4/18 2:09:18 AM :Info: Supported iniSpecVersion=3.51
2/4/18 2:09:18 AM :Info: Read file ms3Supplement.ecu: 33.289886ms
2/4/18 2:09:18 AM :Info: Filtered ini: 0.164249ms
2/4/18 2:09:18 AM :Info: No iniVersion defined
2/4/18 2:09:18 AM :Info: Loading Trigger Wheels
2/4/18 2:09:18 AM :Info: Loading Depricated ini section [UserDefined], use [UiDialogs]
2/4/18 2:09:18 AM :Info: Parsed and validated ini "ms3Supplement.ecu" in : 83ms.
2/4/18 2:09:18 AM :Info: Read file ms3DefaultTools.ini: 0.783704ms
2/4/18 2:09:18 AM :Info: Filtered ini: 0.008958ms
2/4/18 2:09:18 AM :Info: Parsed and validated ini "ms3DefaultTools.ini" in : 17ms.
2/4/18 2:09:18 AM :Info: Time to load primary config: 1645.0425ms. used cached config: false
2/4/18 2:09:18 AM :Info: Read file ms3_1.2_WueAnalyzeMap.ecu: 1.104743ms
2/4/18 2:09:18 AM :Info: Filtered ini: 0.149666ms
2/4/18 2:09:18 AM :Info: Parsed and validated ini "ms3_1.2_WueAnalyzeMap.ecu" in : 22ms.
Exception in thread "ProjectOpenThread" java.lang.UnsatisfiedLinkError: jnidispatch (/com/sun/jna/linux-arm/libjnidispatch.so) not found in resource path
at com.sun.jna.Native.loadNativeLibraryFromJar(Native.java:722)
at com.sun.jna.Native.loadNativeLibrary(Native.java:699)
at com.sun.jna.Native.<clinit>(Native.java:114)
at com.ftdi.FTD2XX.<clinit>(FTD2XX.java:129)
at com.ftdi.FTDevice.<clinit>(FTDevice.java:46)
at U.b.l(Unknown Source)
at h.r.b(Unknown Source)
at g.c.a(Unknown Source)
at ag.hA.a(Unknown Source)
at ag.h.c(Unknown Source)
at ag.h.a(Unknown Source)
at ag.A.run(Unknown Source)
2/4/18 2:10:56 AM :Info: closeApp Called
2/4/18 2:10:56 AM :Info: Finalizing Sensors
Saved user properties successfully
