version 0.1
file:
http://www.deskbreaker.com/wiglaf/e30/m ... dave1.dash
EVOLUTION/CONCEPT:
original post:
Your software is what I've been looking for to finally make the jump, to an LCD dash.
I'm working on the layout right now and am running into a few hurdles, since it is early and you seem to be keen on having this UI custom-friendly, I want to be open with what I'm trying to do. I drew this up before I ran into your software which is part of why it's difficult to implement.. it's more artistically oriented than anything. Hopefully this is the sort of feedback you are looking for?
basic layout is this:
Code: Select all
####((((O))))
each '(' is analog meter set up to be concentric w/ rpm gauge. they are skinny, compact. I only left room for numbers, the labels would be angled/vertical at the bottom.
the '#' is the histogram style chart, showing the history of each gauge on the left side of the RPM.
the ones to the right of the RPM will be the less-watched ones, fuel, coolant, etc.
the bulk of the artsy stuff i think I can hack with a background image, and make most of the gauges clear. This takes care of placing labels and such, although being able to add some plain old text labels and maybe basic shapes would be convenient.
hurdles:
changing window size (such as window->full screen) messes up the layout, particularly obvious when you have round analog near rectangular analog.
interface is very clunky when it comes to indicators/gauges overlapping, there is no way to lock anything in place.
analog gauges to the right-hand side read upside down (low values at top). need a mirror option.
historical graph can't overlap another without covering it up. I was hoping to tweak these into colored lines. kinda megalogviewer-esque sort of style. But if you wanted to add adjustable transparency or some kind of fade-out effect that would be cool too.
will eventually want to add indicators for things like turn signals. Adding custom indicators was brought up in another thread, but not the aspect of something with an odd shape that does nothing but change color. would using small images be appropriate for this?
off.jpg, on.jpg or something of that sort seems like it would be the easiest in terms of avoiding a pile of option dialogue and the most customizable to the user. just brainstorming here.
edit:
also I kept wanting to find an option to hide the text in the middle of the analog gauge, want to put speed readout in the middle of the RPM analog
