TS 0.982.3
Thank you for adding the name of the msq file to the title bar. However, it doesn't update properly.
If I open or "save as" an msq file the title bar does not change.
If I open a different project, the title bar changes to the msq that was open in the prior project.
Title Bar msq Indicator
Re: Title Bar msq Indicator
Sorry, I haven't actually put in any sort of display for the current msq that is open. I will.
All that should be showing in the title bar is either the signature of the projects firmware if you are offline and if you go online it will be the firmware description pulled from the controller. I'll put something in the status bar perhaps... Maybe a little info center that displays multiple things on click and you can select what you want to see by default.
Hmmm. I've just been running offline, not connected. When I have a project open, and then open another project the msq file name (from the previous project) appears on the title bar.
No worries. You reminded me to put it in. So next release has the file name in the status bar
