update v0.982.3
update v0.982.3
new update v.982.3 just apeared on win 98 computer,but not on myone w/vista.where can i find it ? and how can i change my vista to get the auto update?
62 f100,uni body,4.6 motor&updated chasis, ms2 micromodule
Re: update v0.982.3
after reading through the post i found the help option brings up get updates.
Re: update v0.982.3
I wonder what's mew with that update.
Ford 342 stroker | 4inj.TBI
MS2/Extra beta RC3 2.1.0 20090611
Re: update v0.982.3
You know I already forget
Fixes for custom.ini
fixes for MS1 Base Code connections
Fixes to the 3D tables.
There are some new things too, but ?
The release about to go out has all 2D tables switch to a 3D view.
And I have a new Tuning tab that will be in the release after that.
Re: update v0.982.3
having some problem setting up fan control.ive turned on output 1,3&4 put 240 as on off temp 20 hyrst,but they turn on the output on the screen when the needle hits 60.(not sure if output is coming on,im at desk using stim).ms1 v2.2 msns 29y4.
Re: update v0.982.3
62f100, I guess is this a firmware issue you are having? Or is this behavior only while using TunerStudio?
have you tried something lower than 240?
Re: update v0.982.3
il try the same thing on megatune & see what result i get.
Re: update v0.982.3
it must be a firmware issue because it does the same thing in megatune .im using the ford sensor therm files.would that be the problem?
