auto detect?
auto detect?
Does TS auot detect for INI, I thought I remeber when I first set it up, it did. I wanted to give the new code(2.1.0) a try as it address a few problems I have been having. I did the INI copy bat file and MT is working ok however TS is giving me mismatch code version error.............
Re: auto detect?
You will need to go into the Project properties while the project is open.
Menu:
File --> Project --> Properties
Either select your new firmware from the drop down, or click other and browse to where the new ini is on your hard drive. TS will copy the file to the right place and reference it.
I need to get the detect for new firmware in place and make the server answer the door. Right now it you do the check on EFIAnalytics.com, it still isn't working I need to deploy the web service to the production environment.
Menu:
