Now with work a bit more sensible and some horrible family issues now resolved I have turned to TS for some 'TS therapy'
I have MS1 V3 029V MS SnE
Looking at the configs there is not 029v
Is there any way 029v could be added,
there are a number of us in the UK that share our knowledge and use this,
I am keen to now get some serious use and testing on TS but this seems a bit of a stumbling block,
up to now I have used MT and MLV for dtalogging and TS more for "Display" which is a big and crazy situation,
but using 029v I get warning pop up on loading
and I am worried that not having 029v and no errors as a config for the ECU could mean problems in the ECU software going forards
Pleeeease can you HELP PHIL !
Nige
ECU Firmware Q on TS
on http://www.LR4x4.com (Land Rover forum post under Hybrid_From_Hell)
http://www.megasquirt-v8.co.uk On line webshop for all things V8 .....Particularly V8 Rover and Megasquirty
Re: ECU Firmware Q on TS
In the new Project Wizard, on the first page, where the "ECU Definition" drop down is; Just below it check the "Other" check box. Then the ... Button. You can browse to where ever your ini is that you have been using in MegaTune. It will copy it into your new project folders.
You can do this with any ini that works in MegaTune!
