TS 0.984, MS1, Extra 029w
Custom inc files for MAP, MAT and CLT. Map type is 115 kPa, which uses the kpafactor4115.inc file, which I have customized.
All inc files for this project are in the mtCfg directory of the project. The project directory was set up by/for Megatune.
TS does not recognize the map signal.
10/26/08 8:40:08 AM Debug: Could not get value for OutputChannel:map
MAT and CLT are incorrect values.
Copy kpafactor4115.inc to the TunerStudioMS/config directory, restart, and MAP works.
It seems that TS is not reading the inc files from the project. Am I doing something wrong?
Thanks,
Marty
Project Inc Files Not Used
Re: Project Inc Files Not Used
TS first checks for the inc files in the folders:
[Your Project]\inc\
Then
[Your Project]\projectCfg\
last in the:
[Application Install Dir\inc\
mtCfg is never referenced by TunerStudio as that folder doesn't exist in a TunerStudio Project.
[Your Project]\inc\
Then
last in the:
Oops, yes I should have said TunerStudioMS\inc.
Thanks, I'll try the Project\inc directory.
[Your Project]\inc\ didn't work.
[Your Project]\projectCfg\ worked for all the inc files.
If you go to the Menu:
Help --> About
What version does it say you are running?
Because a few versions back it was only looking at the projectCfg and if you are running vista auto update can not work properly when not run as Administr4ator.
Help --> About
v0.984
Running XP
Running XP
Ok, thanks. I'll look into it.
