I noticed something while tuning idle advance settings.
If you want to type in a negative number, it will not let you type in the "-" symbol. The only way to get "-10" (to use table), is to use the up/down arrows to dial it down. Perhaps a better way to fix that would be to store the initial value somewhere and test the new value when the text field is out of focus? Meaning after the user has plugged in a value and clicked outside of the text field, check to see if the value is valid and if it's not, pop up an error message and return to the initial value.
There were a few more, but I don't remember them all right now. That's using version 0.984
A bug in the GUI
A bug in the GUI
2000 Saturn SL2 - Boosted @ 15 psi - MSnS-E PCB3.0
Fully forged, P&P, balanced to 9k RPM, fuel and spark
Re: A bug in the GUI
Thx. I'll take a look.
