Hi Phil!
I have now used tunerstudio for a long while now, and I simply love it. But I have found a few bugs.
I am adjusting the AIT corrected enrichment just now. First thing I was trying to do, what to turn off the correction, but I cant find it in tunerstudio, only where to correct it! But if I set it all to 100% I still can see movment in my log, both on gammaE and in GAIR. What can it be that gives me that gammaE correction?
Here is a log http://www.ljbk.dk/saab/ms/log/airt.msl
Here is my latest msq http://www.ljbk.dk/saab/ms/msq/ljbk,7.msq
Here is the funktion in MT that is missing in tunerstudio.
AIT corrected
Re: AIT corrected
Kaas,
Thanks for spotting (and reporting!) the missing dialog... It is defined in the ini, but not added to the child dialog menu. I will see for sure when I get in the code, but I thought the dialog sub menus was implemented, I might have broke it.
As for your Gair, those settings are for additional corrections to air density based on changes in coolant temperature, but even with that off, the firmware has correction for air temperature readings from the MAT and I don't think there is a way to turn that off other than disconnecting the MAT sensor
Re: AIT corrected
Ok, as long that I know that, then its ok!
But I am looking forward for the new changes, so I dont have to use both ts and mt. I mostly like ts!
Re: AIT corrected
Have a look at the Knock Sensor Setting too. It is vanished in TS.
Only the Knock threshold table is available.
(4G63T - MSIIextra) (4G13 - MS3-beta testing)
Re: AIT corrected
What knock sensor setting? Is it a menu on a dialog?Gokart wrote:Have a look at the Knock Sensor Setting too. It is vanished in TS.
Re: AIT corrected
Maybe this can make your understand better.
Re: AIT corrected
Ok, thanks. That is the same as above, the menu is getting added to the dialog.
