Comms problem
Comms problem
I've recently installed tunerstudio, after hearing great things and it looks wonderful, but I'm unable to communicate with my ECU ( MSII Extra 2.0.1 ). I've been using megatune and it is still able to communicate.
I created a new project, pointed the ECU Definition browse box at the megasquirt-ii.ini from my megatune project folder and use the ECU test button but it fails. I have also tried the test from the communication > settings menu and this too fails.
I am using a USB to COM lead currently and this assigns me COM4 or 5 depending on the USB port I use.
Any help greatfully recieved as I am excited to give this new software a try!
Luke
Luke
If I had six hours to chop down a tree, I'd spend the first four hours sharpening the axe.
Re: Comms problem
Couple questions...
If you just click detect, does it find your controller?
It should be detected as MS2 Extra 2.0.0 as the signature and ini did not change for 2.0.1
Is MegaTune Closed?
If MegaTune is open, it will be holding the Port so TunerStudio won't be able to access it.
Is MegaTune Closed?
Re: Comms problem
the detect button returns "No device found, check your connections"
Megatune isn't running simultaneously.
Ive tried opening up the mini terminal, not exactly sure what I'm doing with it but I would expect some header information upon connection and recieve nothing, it seems the software just can't get a hold of the com port, but megatune and the portcheck program that comes with the DIYAutotune software pack both detect it fine.
Re: Comms problem
I haven't forgotten you... Just trying to think of what is up. I haven't seen this on windows.
I assume you used the installer and are starting it from the icon?
Are you running on a Bench or in a car? I bought a whole pile of USB to serial adapters to use for testing, almost all of them worked fine on the bench. However, I have been finding that several of them get rather troublesome in my car.
Maybe I can find something in the TunerStudioLogFile.txt in the install dir. But I might need to add a comm debug option in the next release to get some additional information.
If you have a different USB to serial adapter, give it a shot. But if you are connecting with MegaTune, i dunno. It usually works the other way around. TunerStudio can typically connect with cables MegaTune can't.
Re: Comms problem
Yup, used the installer and starting with the icon.
I'm trying it on the bench with power coming from my megastim.
I don't have a different USB => Com but I'll give it a try on my old lappy which has a serial port but I guess that'll just prove it's not the ECU causing the problem. Is there a list of adapters that have tested okay in case I need to buy another?
The USB adapter is a hugepine one like this: http://avr.auctionant.de/img/ark3116_pi ... e_pack.jpg
This is from the log, I presume where it was going through the detect routine as it is in the middle of a list of attempts at different com ports.
12/11/08 08:48:34 :Error: Exception reading port://./COM4, @115200 Baud. Error Message:
No error in nativeDrain
12/11/08 08:48:36 :Debug: 2494ms. - Reset Port
12/11/08 08:48:37 :Error: Exception reading port://./COM4, @9600 Baud. Error Message:
Bad file descriptor in nativeDrain
12/11/08 08:48:39 :Debug: 2463ms. - Reset Port
12/11/08 08:48:39 :Error: Exception reading port://./COM4, @115200 Baud. Error Message:
12/11/08 08:48:41 :Debug: 2494ms. - Reset Port
12/11/08 08:48:42 :Error: Exception reading port://./COM4, @9600 Baud. Error Message:
Re: Comms problem
Hey I have that cable! It is sitting on my desk, it is the only one I have come up with that doesn't work for me either. But I haven't gotten it to work with MegaTune or a terminal either. I have tried it on linux and windows, but I think on windows I may have a driver conflict. It is showing as a Prolific ... So maybe it is picking up the driver I installed for another cable.
That error "Bad file descriptor in nativeDrain" is interesting.
I think I'll give that cable a shot on another computer that hasn't had 10 other cables plugged into it.
Re: Comms problem
Hi All,
I have same problem but com port is fisical device COM1, I just dwnload and install TS.
When I click to test comm. it say failed.
I see with com-port monitor that TS sends 'Q' and controller responds whit "signature", but TS do it in a LOOP.
I tryed an mini-term but it doesn't work too, I see with com port monitor that it open an close port but, nothing can't be send over it.
I foun this in log file:
08-11-12 21:01:02 :Error: Exception reading port://./COM1, @115200 Baud. Error Message:
Read timeout for send command: 81 (Q)
Expected Unspecified bytes, still no reponse after 200
08-11-12 21:01:02 :Debug: 406ms. - Reset Port
08-11-12 21:01:02 :Debug: 406ms. - ReOpened Port
08-11-12 21:01:09 :Debug: removing COnfiguration: MyCar
TunerStudio shutdown: Wed Nov 12 21:01:09 EET 2008
And some question - Is it a way to start MSTS on windows mobile device ?
Re: Comms problem
goaman,
This sounds like a very different problem. You are seeing the command sent and a response, but it seems TS has already timed out and declared failure or something like that???
What sort of do loop?
I would like to get a better understanding of this as with a real cable and you actually seeing the response come through, apparently it is working. I need to see why TS is missing it.
What windows are you running on?
No mobile devices yet.. That will take a different version.
Re: Comms problem
Well today I went out to do some datalogging using megatune and discovered, although I get comms okay with this cable, after a while it goes mad and i get stupid readings all over the guages with the car continuing to run fine (I'm talking 50krpm tacho readings). It seems the long and short of it is the cable's a piece of crap.
I think the best solution is just to get a new com -> usb lead, as you've tested a whole bunch could you recommend one that works well with tuner studio?
Re: Comms problem
I would like to do some more research before making any suggestions, because....
The laptop I usually use in my car has a real serial port (Dell D610) and most of my usb to serial testing has been on the bench. Lately I have used another laptop that needed the usb-serial adapter and once I hit the real world.... I am finding what you have, all the noise in the car screws them up. Apparently most of these cheap ones were not really designed for the noisy environment inside a car, especially a concoction car like mine .
So far I have had issues with drop out on 4 different cheap cables that worked fine on the bench. Also TS 0.984 will often then get stuck and not reconnect, actually it may take task manager to kill it. I have fixed this for the next release.
But still need to look for a good reliable usb cable. Perhaps there is good reason to step beyond the $5 cables
diy autotune has one that they recommend. I haven't tried that one yet with TS, but I bet they have and I know they must have used it a lot with MegaTune.
Re: Comms problem
Even though serial adapters works for me but it's only good on the bench...
When using it in the car, most of the time it drops out. Unless with my
expensive ATEN cable which is working as expected, using 'Hugepine'
and some other unbranded converter sometimes cease to connect at all.
Now I choose to use expresscard and it's a breeze just like using the real
serial port. No hiccups anymore even though it's prolific too.
I even tried bluetooth with TS, it works fine with both MS1@9600bps or
MS2@115200. Unless if I switched off the MS and get the bluetooth
disconnected, TS will freeze and need a restart. So the trick is to close
TS before switching off MS. I know Phil is being working on this and
hope that he is able to iron out that problem in the next release.
(4G63T - MSIIextra) (4G13 - MS3-beta testing)
Re: Comms problem
Gokart, thanks that is good info. And supports what i have been finding too with the cheap ones.... The other day I was out away from home with 2 cheap cables that I have used for bench testing a lot, on the street they were only good for a couple minutes.
Yep it is fixed, I just need to get the rest of the build done.Unless if I switched off the MS and get the bluetooth disconnected, TS will freeze and need a restart.
Re: Comms problem
Perhaps I'll go back to my old lappy with serial port for now then
Re: Comms problem
I've used a Belkin USB-Serial adaptor with MS and TS without problem. These come with dedicated drivers for different operating systems (Windows and MAC).
I also use a PCMCIA card that never fails.
Re: Comms problem
Hi Phill
I've been very busy, but tonight i see that my problem is that time out is 200ms, but on my PC side response from ECU came aftet 203 ms.
Is it any way that time out to be incrased or I need to wait new release?
Another qustion Is it a way to switch between big and little endian ? - Mega tune do it with [endianness = little] is it works on TS ?
And When you planing to release Mobile device port ?
Thanks in advice.
Thanks in advice.
Re: Comms problem
203 ms... That is interesting. The normal response time is 25-50ms, so 200 normally has a lot of headroom. For connecting, there is no way to change that timing through config. I'll bump it up for the next release.i see that my problem is that time out is 200ms, but on my PC side response from ECU came aftet 203 ms.
TunerStudio does support the same endianness = little, but it has not been tested as all the MegaSquirt firmwares are big. What are you trying to do that needs little?Another qustion Is it a way to switch between big and little endian ? - Mega tune do it with [endianness = little] is it works on TS ?
It is definitely on the roadmap, there seems to be plenty of demand, but it will be a while still. I need to get this one finished and that pesky day job gets in the way.And When you planing to release Mobile device port ?
Re: Comms problem
I'm runing my own ECU firmware on diffrent microcontroller wich is little endian.
Comunication is same as in MS.
But there are some issues wit Megatune an little endian.
Megatune cant send correct size, 1 byte is send as 100 in llite endian mode but, I fix it for me in my firmware.
And now I have no problems with Megatune, and it's works for me .
But TS looks more than cool .
Regards
Regards
