Accel Enrichment Wizard
Stag76
Post by Stag76 »
I've just started using TS, and have transferred my MSQ's from MegaSquirt.
The highest Accel Enrichment KPA Point was set to 800, and I couldn't access it with TS, so I reset it to 500 using MS.
How do you set or amend these KPA Points?
Kurt A
Re: Accel Enrichment Wizard
Post by Kurt A »
Stag76,
I noticed the same thing on first start up. To change the dot settings just left click the blue dot. It will change to red and then you can use your L/R arrow keys to move around from dot to dot. Holding the shift key and using L/R arrow key creates a change in the value as does up / down arrow keys. You can also drag and drop the dot being worked on to wherever you want.
Kurt
Rotax 912 turbo'd under construction MS2 Extra
2005 Mustang GT, turbo'd, aluminum heads, MS2 Extra
1928 Ford Coupe, 545BBF,671 blower, Squirted by MS2 extra 3.1.0, V3.0 Board
Post by LT401Vette »
The desired max seems to vary a great deal on these. I think I need to put in some sort of a user override as i have gotten reports of both being off the chart and being bunched up to once side.
Kurt A
Post by Kurt A »
Phil,
I think this is only occuring with MSQ's created by MT and being brought in to TS. Still, would be nice to have the max floating as per user choice.
Kurt
Stag76
Post by Stag76 »
The Accel. Enrichment is working just as well with the Max reduced to 500.
