I just took a look at TS and it looks really neat based on my first impressions. One thing I noticed is the realtime display and while it's handy to have all the variables there, it isn't very useful. One of the nice things when looking at the MT realtime display is that you see all the core essential values and can usually debug a problem from that screen. When the problem is deeper, opening up a log in MLV would be called for.
Or... have the MT bar graph realtime display with all the other variables displayed below... or have the option to select which runtime display is desired..
thanks!
Mike
realtime display
Re: realtime display
I have it on the todo list to put in a summary view for realtime display.
I had to put something there because the ini does put it on the menu, but I didn't think it provided as much value as it is in MegaTune with all the other dashboard options.
I'm thinking perhaps a tab so you can view the current all output channels, as there is no where else to do that. But on the other tab a dash with a view more similar to MegaTune. But, also keep in mind I am going to have multiple dash views on a quick switch on the main window too. So over time I see it perhaps becoming extinct.
Ahh.. yeah. Then I'd just leave it as is so you have the full output channels view and then like you said, use a tab to see the variables you want to see in any format - makes sense. The other perk about the tab is that they are easier to get to rather than going to that menu. Sounds good!LT401Vette wrote:I'm thinking perhaps a tab so you can view the current all output channels, as there is no where else to do that. But on the other tab a dash with a view more similar to MegaTune. But, also keep in mind I am going to have multiple dash views on a quick switch on the main window too. So over time I see it perhaps becoming extinct.
mike
