after a little bit of experimentation, I figured out that holding shift while pressing the arrow key changes the temp bins. That's handy, but it moves pretty slowly and could be painful if you need to really move things around. You might set it so ctrl-arrow changes it a lot and shift-arrow changes it a little.
The other option is doing something similar to the MSII where they have a menu for changing the bins (I think that's what they do), but it would still be nice to have something similar to the mt setup where the bins and their associated values are next to the table and editable.
changing temperature bins is kinda tedious
Re: changing temperature bins is kinda tedious
Good point. I put the control in for the 3D table but didn't on the curve's
Thank for all the feed back!
Noticed you put in ctrl-shift to move temperatures more quickly. Thanks!
Mike
Mike
