Hi Phil,
I just tried out Lance's MShift code on the GPIO with Tunerstudio and TS will not communicate with it at all. When I go into the Communication settings and test the port it just comes up failed. It works fine with Megatune. I had no problems with TS when using James's trans code or MS2extra.
Cheers
Daniel.
GPIO + CAN + Transmission Control.
26 Chev hotrod with a 1UZFE and MS3x, Flex fuel, GPIO Transmission control and LCDash.
Twin turbo LS3 powered Race boat with MS3pro and GPIO.
MS2 on a 22r in a Hilux (mates car).
MS2extra on a turbo EF Falcon (brothers car).
Toyota Supra 1jz MS2extra, COP.
13B Turbo MS2extra.
13B Turbo MS2extra.
Re: GPIO + CAN + Transmission Control.
I guess I better get the GPIO code going . So far I have only tested CAN through MS2Extra 2.0.1 to James' Trans code.
Are you running Extra or base code on the CAN 0? Then attempting to talk to the GPIO through that?
I am using MS2extra as CAN 0 but I was connected directly to the GPIO serial port when trying lance's code.
cheers
Daniel.
cheers
Daniel.
13B Turbo MS2extra.
13B Turbo MS2extra.
Oh... So you aren't able to speak directly with the GPIO? The ini loads ok though? Can you send me the ini you are using?
Yeah the ini loads fine, just the coms won't work. attached is the ini I'm using. It should be the same as the current one that can be down
loaded from the GPIO forum.
Cheers
Daniel
Cheers
Daniel
13B Turbo MS2extra.
13B Turbo MS2extra.
I see why, easy fix for next release. which is mostly about CAN.
