Thanks Phil,
Temps are reading correctly now as well. Installed thermfactor.inc and matfactor .inc as you advised (not in the app install directory). Do I not need to install the airdenfactor.inc file? That file is created by easytherm as well when you create the other 2. I am under the impression that it is needed to match your 2 temperature files.
Kurt
Update failed
Re: Update failed
Rotax 912 turbo'd under construction MS2 Extra
2005 Mustang GT, turbo'd, aluminum heads, MS2 Extra
1928 Ford Coupe, 545BBF,671 blower, Squirted by MS2 extra 3.1.0, V3.0 Board
Re: Update failed
In MS1 Extra 29, I don't see any references to airdenfactor.inc, perhaps it is in used in an older firmware?
If you add it, it won't hurt anything, but you shouldn't need it. Unless I'm missing something, it isn't used with your firmware.
Re: Update failed
Just wanted to say thank you for the info.... I had the same problem after updating tunerstudio "application files updating" . I have never updated my tunerstudio in 7 years of using it lol guess I need to do a firmware update now.
