probably something your already working on but i thought i'd ask anyway.
When i attempt to change my outputs with "output port settings" I get the error as per the subject line.
No biggie. just like everybody else i'm just waiting for the day i can use this fully
std_port_edit not found
Re: std_port_edit not found
Uh, Somehow, until just last week I forgot about that. I guess I just don't change output ports often enough
I'll have to get it done just so it is of the list, that and the trigger wizard.
For MS2 the output ports are hard coded into Megatune, but in writing the new code in TS, consider that for MS3 we'll certainly want more ports specified in the ini and for MS2/Extra now we could possibly add a few more.
I'll try to make sure the dialog is built from meta data so it can be pushed to or over-ridden the ini.
