Ok, got the last update and looking at the trigger setup i'm trying to understand how to configure this trigger wheel setup/trigger return or edis setup.
my current setup on another MS is with a 36-1 trigger wheel running wasted spark coil pack scenario. Sensor is positioned as per edis setup (6 teeth) or 60 degrees if you like. what would i need to set the trigger angle/offset at for a KL series engine
what would be the best configuration so to speak
36-1 setup confusion
Re: 36-1 setup confusion
Which MS version is this, and what firmware is it running?
Sorry. MSII MS2Y i beleive
Try the settings at the very bottom of this page.
http://www.diyautotune.com/tech_article ... erview.htm
Thanks for that Matt, My settings are almost identical to those. The only difference is these instructions state to set the number of missing teeth as two when i only have a 36-1 wheel on my crank. and i have mine set to one.
My mistake, that was a typo. The article is now fixed.ausloki wrote:Thanks for that Matt, My settings are almost identical to those. The only difference is these instructions state to set the number of missing teeth as two when i only have a 36-1 wheel on my crank. and i have mine set to one.
