1) When I create new gauges, I normally want to copy something that is already there by default. Is there a "copy gauge" feature? I normally have a hard time making them match. It would be nice to just copy the gauge, select the desired channel, and set the limits.
2) How do you edit the gauges and limits in the tuning dialogs? For me the gauges in the VE table screen are very difficult to see/read. I can change the background color, but that's about it. Also, can the tpsdot range be scaled? In MT I changed this in the ini (for me my final TPS AE value is around 60%/s, so the table looks quite crunched).
The software is great, and looks really slick. Thanks for all the work put in. The only thing I use MT for right now is uploading palmlogs and output port settings.
Love TS, few oddball questions
Re: Love TS, few oddball questions
There is no copy paste for the gauges yet, but that is one of the first things on the list when I switch back to dashboard stuff. I already have a plan on how I can do that pretty easily. I've been more focused on the tuning side again now.1) When I create new gauges, I normally want to copy something that is already there by default. Is there a "copy gauge" feature? I normally have a hard time making them match. It would be nice to just copy the gauge, select the desired channel, and set the limits.
The way it is now, how I make the gauges look the same is using multi-select. For any of the attibutes, if you change them is will apply to all that are selected. You can select multiple gauges by dragging the mouse, or by holding the CTRL key and clicking on each gauge you want to select or un-select.
In the tuning dialogs you can right click and go into designer mode. In the curves, you can only edit them by editing the ini file at this point. If it is tpsDot in the accel Wizard you want to change the limits on, it is on the list too ( I think you requested it?) But I haven't gotten to it yet. I will2) How do you edit the gauges and limits in the tuning dialogs? For me the gauges in the VE table screen are very difficult to see/read. I can change the background color, but that's about it. Also, can the tpsdot range be scaled? In MT I changed this in the ini (for me my final TPS AE value is around 60%/s, so the table looks quite crunched).
the port editor should be in the next release, and palm logs is coming soonThe only thing I use MT for right now is uploading palmlogs and output port settings.
