I know this was added until recently, so guess it may still be in development, however, in MT, I have a fan to turn on at 80 degrees Celsius, with 2 degree hysteresis.
In TS it reads very odd values, ie. Hysteresis at -18
If I put the correct value in TS and burn, they are then messed up in MT.
Also, in MT only one output is active, but in TS there is funny data in outher otuputs as well (afraid i can't remember if those outputs were active or not).
Is this a known issue?
TS 0.987.4
Firmware 2.1 beta (13/01)
Regards,
Kristian
Outputs page, MS2
Outputs page, MS2
Constantly evolving;
4 cylinder n/a, 16v 1368cc Fiat Seicento
Re: Outputs page, MS2
Not a known issue, but let me look into it!
WOW, fast response!
I don't have the car tonight, but can double check, confirm, and test anything you need tomorrow night
Cheers,
Kristian
Cheers,
Kristian
Yes there was definitely a problem with msq compatibility. TS was saving the values to the msq in user terms, already transformed and scaled like all most settings, but MegaTune is saving them as raw values. So using an OutputChannel like coolant, which is scaled and transformed gets messed up in the double transformation
I have it fixed here. I'll get patch release out after a little more testing.
Thanks for reporting this!
And thanks for such a great program, support and speedy developmentLT401Vette wrote: Thanks for reporting this!
