Help with TS Hr 11c1 & Vista LT + LOAD % Baro
Hi
I have a LT with vista on it, I find with TS & Hr 11c1, Baro % is moving from the load point to 0 point all the time, on my PC with XP I find it to Be good.
I have a DL of it behaver. But it is not allowed The extension msl is not allowed.
Please Help
Gavin
Please Help
Gavin
Re: Help with TS Hr 11c1 & Vista LT + LOAD % Baro
Sorry for the delayed response, I was away on vacation this week.
Do any of your gauges bounce here too?
Are you using the same serial connection type on both computers? i.e. usb to serial cable?
Hi Phil
No to Q 1.
Yes to Q 2. usb to serial cable
Phil I am not shore if, I am the only one with this on vista????
Thanks Gavin
No to Q 1.
Thanks Gavin
Vista use has been climbing quite a bit... It is now at 37.5% of the TunerStudio users.
I may have a theory of what is happening...
TunerStudio has quite a few optimizations of the comm timings that I made more aggressive in 0.987. It will speed the comm timings until it sees and error back them up, then speed to within a threshold of the last error.
I have had several people who are getting comm problems with 0.987 that did not have them with the previous releases, so I think I may have gotten too aggressive with the optimizations in 0.987.
Now that you mention it, I think almost all my comm complaints have been by Vista users.
I will have another release out within the next week or 2, let's see if that fixes it for you. Actually, perhaps I should put out a patch release sooner.
Phil
Thanks.
Gavin
Thanks.
Gavin
Hi Phil
This is 80% better, Still bouncing.
Thank for the improvment sofar.
I hope this daterlog will help
OPPSS no log
Mine does this too, and im using XP, but also hr11c1. Ive recorded a movie of it, if you would like to see it?
Sorry for the bad english
Ok, so this sounds like it is not serial related perhaps.
You are not getting data spikes throughout, but a specific one? LOAD % Baro
I'll load that firmware on one of my controllers and see if I can reproduce this.
You are seeing this in the data logs and on gauges, but just for LOAD % Baro?
No it does not show in the datalog
http://www.youtube.com/watch?v=_MBjROBAjcI
Hi Phil
Phil the serial change help 80%.
Gavin
Gavin
Hi Phil
Phil , Hr 11c1 is spot onThank you Phil
Keep up the excelant work
Gavin
Gavin
