Can not add indicators?
Have been playing with TS a bit trying to set up a dash to my liking.
I can add a new indicator but when I want to edit its properties, right-clicking on it does not bring up the menu as it does for a regular gauge?
In fact, I find I can not even delete it after adding it.
Kind regards
Philip
Philip
Re: Can not add indicators?
Hmm, that is interesting...
Is it not selecting with the yellow lines?
Yes, its selects and gets the lines with the 3 yellow and 1 red dot but when I right-click, nothing happens.
Kind regards
Philip
Philip
Hmm On all the indicators, or just a new one you are adding?
If you check the About box, on the Menu:
Help --> About
What Java Runtime version are you on?
Help --> About
1.5.0_05LT401Vette wrote: What Java Runtime version are you on?
Is that outdated and thus the problem?
Kind regards
Philip
Philip
That should be fine. Anything 1.5 and greater should be good.
If you can send me your TunreStudioLogFile.txt from the install dir, that might shed a little light on it for me.
p_tobin<at>yahoo.com
Phil
Just stand down on this issue for now. Looks like we are just having dumb user problems at this end.
Kind regards
Philip
Philip
