Customizing graphs ( like gauges can be)
Philip Lochner
Post by Philip Lochner »
Stumbled on an interesting one Phil...
I was using TS to tune my Ms2 Extra 2.1.0 beta 20090225 with.
Wanted to make change on the MAT correction table.
With MT I set my temp bins for 0,10, 20, 30, 40, 60 deg C but the ini file only starts at 100deg C going upwards from there (obviously needs changing in the ini file).
1) With TS I found that using left and right arrow I could see the 40 and 60 points coming up but I could not adjust them using shift up/down or ctrl shft up/down. Does TS only allow adjustment if the points are actually on the graph?
2) Would be nice to change the graph properties in a similar way one can change the gauges. I found other graphs boundaries also not to my liking (adjustable in the ini) but if one could adjust them on the graph... :yeah!:
Kind regards
Philip
Re: Customizing graphs ( like gauges can be)
Post by LT401Vette »
Yeah that has been a common request to be able to adjust the mins and maxes without editing the ini. Especially in the Accel Wizard. I'm going to address this soon. Also going to add some method for textual entry instead of curve graph only.
I would have thought you could adjust them if they are off the scale. I'll have to look at that.
