Custom gauge only on main screen?
Hi Phil
I created this AFRerr gauge that I place so much importance on and it works on the main screen.
1) But now I want that gauge on the 3D tuning screens as well but when I right click, this AFRerr gauge is not offered. Does that mean I have to re-create it for each of the 3 tuning screens? (VE, AFR and timing?)
2) While on the subject of tuning screens. Can I make the tuning screens with the 3D graphs go full screen? Would be nice if one could.
3) How do I make the red dot follow the yellow operating point automatically? Pressing G as per MT does not seem to work.
Kind regards
Philip
Philip
Re: Custom gauge only on main screen?
The only gauges offered as templates currently are the ones defined in the ini file.
But I am thinking that is a good idea, offer the option to add any gauge you have made as a template. I'll put that on the list.
What you can do, is right click on your gauge and save it (only while in designer mode),
then go to your second dash and right click "Load Saved Gauge"
Also coming soon is copy & Paste of gauges, that would sort of take care of it too.
Do you mean a frame less full screen like the dash, or just have a maximize button on the dialog so you don't have to strech it to full screen size?2) While on the subject of tuning screens. Can I make the tuning screens with the 3D graphs go full screen? Would be nice if one could.
Sorry, that is on the list but not there yet. It will be soon.3) How do I make the red dot follow the yellow operating point automatically? Pressing G as per MT does not seem to work.
That's a good idea Phil !! Let's have it. Also hit "f" and the tuning screen goes frameless full screen just like the dash. (some of us don't have the hawk -like eyes of the youth ) Esc makes it return to previous frame size and "q" closes the tuning screen (with a question to burn if a burn did not preceed the q command??)LT401Vette wrote:Do you mean a frame less full screen like the dash,
If the above is too difficult, a maximise button will do fine - just like MT.LT401Vette wrote:or just have a maximize button on the dialog so you don't have to strech it to full screen size?
Kind regards
Philip
Philip
Just give it the regular maximize box - but make it remember the last size used so I only have to adjust it once.
It should remember the last size you used. But that is at the project level and for each specific dialog.
I got one... the spark advance is reading with the triggle angle added to it instead of just the value on the map. It throws me off since I look at the map and set it to 20 or so, then on the dash it reads 85
I'm working on another dash layout, it will be less confusing. On that last one I think I had too many things piled up, I still can't get the concentric thing to work out very well.
I like the idea of AFRErr gauge - but how have you created it? The datachannel needs to be calculated first? How?
1998 Landrover Discovery I V8 3.9, MSII/E ver RC 2.1.0 20090505; EDIS8; wideband LC-1
In the custom.ini file or megasquirt-ii.ini of the Mtcfg directory of your project add the following in the correct places:
For some reason afrtgt1 is 100 times greater than afr1...
Then in MT, right click and put the gauge where you want it or change the [frontpage] section as follows to make MT show it automatically when you start it up. Same applies if you use TS.
Code: Select all
[GaugeConfigurations]
AFRerrGauge = AFRerror, "AFR error", "", -2, 2, -2, -1, 1, 2, 2, 2
[OutputChannels]
AFRerror = { (afr1 - afrtgt1 / 100) }
Code: Select all
[FrontPage]
#if NARROW_BAND_EGO
egoLEDs = 0.0, 1.0, 0.5 ; Voltage settings.
#elif LAMBDA
egoLEDs = 1.5, 0.5, 1.0 ; Lambda settings.
#else
egoLEDs = 20, 10, 15 ; Afr settings.
#endif
; Gauges are numbered left to right, top to bottom.
; 1 2 3 4
; 5 6 7 8
gauge1 = tachometer
gauge2 = gammaEnrichGauge
gauge3 = pulseWidth1Gauge
gauge4 = afr1Gauge
gauge5 = advdegGauge
gauge6 = mapGauge
gauge7 = matGauge
gauge8 = AFRerrGauge
Kind regards
Philip
Philip
Thanks a lot.
