Starting to use TS on ubuntu. Created project, selected the properties (degC, wideband etc.) - took the msii extra beta 20090201.ini file and my last msq (from megatune)
When I first open the msq (saved in Megatune_ I get this list of errors:
17 Warnings:
Warning: MSQ Units Mismatch for IACcoldtmp! �C found in current configuration, °C found in MSQ, values were not converted to new units.
Warning: MSQ Units Mismatch for IdleHyst! �C found in current configuration, °C found in MSQ, values were not converted to new units.
Warning: MSQ Units Mismatch for clt0! �C found in current configuration, °C found in MSQ, values were not converted to new units.
Warning: MSQ Units Mismatch for egoTemp! �C found in current configuration, °C found in MSQ, values were not converted to new units.
Warning: MSQ Units Mismatch for fastIdleT! �C found in current configuration, °C found in MSQ, values were not converted to new units.
Warning: MSQ Units Mismatch for mat0! �C found in current configuration, °C found in MSQ, values were not converted to new units.
Warning: MSQ Units Mismatch for tempTable! �C found in current configuration, °C found in MSQ, values were not converted to new units.
Warning: Parameter in msq, but not in current configuration: No options found for Bit EcuParameter:tempUnits
Warning: MSQ Units Mismatch for fc_clt! �C found in current configuration, °C found in MSQ, values were not converted to new units.
Warning: MSQ Units Mismatch for matCorrTemps! �C found in current configuration, °C found in MSQ, values were not converted to new units.
Warning: MSQ Units Mismatch for matTemps! �C found in current configuration, °C found in MSQ, values were not converted to new units.
Warning: MSQ Units Mismatch for pwmidle_clt_temps! �C found in current configuration, °C found in MSQ, values were not converted to new units.
Warning: MSQ Units Mismatch for pwmidle_crank_clt_temps! �C found in current configuration, °C found in MSQ, values were not converted to new units.
Warning: MSQ Units Mismatch for temp_table_p5! �C found in current configuration, °C found in MSQ, values were not converted to new units.
Warning: MSQ Units Mismatch for N2OClt! �C found in current configuration, °C found in MSQ, values were not converted to new units.
Warning: MSQ Units Mismatch for RevLimLookup! �C found in current configuration, °C found in MSQ, values were not converted to new units.
Warning: MSQ Units Mismatch for idleadvance_clt! �C found in current configuration, °C found in MSQ, values were not converted to new units.
What do they mean - what do I need to check/adjust?
MSQ Units Mismatch for ...
1998 Landrover Discovery I V8 3.9, MSII/E ver RC 2.1.0 20090505; EDIS8; wideband LC-1
Re: MSQ Units Mismatch for ...
They won't hurt anything, because it is C to C. So the settings will all be right.
I am curious why the units are coming up different though. It looks like the unicode character for deg is getting switched, but it doesn't for other firmwares. I'll have to look at that and see if I can reproduce it. If not I may ask for a copy of some stuff.
Thanks,
This on is also OK?
This on is also OK?
Im having this issue as well!
1986 Porsche 944 Turbo
2.7 liter MID sleeved big bore, Wossner pistons, Vitesse Stage 2 turbo, coilovers, various weight deletes, and loads of other stuff.
I'm not actually reproducing this to see what the strange degree char is. Can someone post msq where you are seeing this?
It again won't cause any problems.
That is the model I use here, if it is a warning, it is nothing to worry about, information only. Sort of to help developers. If TS can not figure out how to resolve the situation, it will report an error. By default you will only be prompted if there is an error, but if you turn on the advanced setting you will be prompted for warnings too.
Actually the temp units change is such common and easy to solve for, I think I will just handle the conversions so you can open a C based msq in a F based project and vice verse.
Sounds good.LT401Vette wrote:Actually the temp units change is such common and easy to solve for, I think I will just handle the conversions so you can open a C based msq in a F based project and vice verse.
The msq causing the mismatch in C is attached.
