I think I found a little quirk tonight, check out this post for details.
http://www.msextra.com/viewtopic.php?f= ... 60#p203520
Mike
Negative Numbers
Re: Negative Numbers
Good point
I guess I'll need an alternative hot key.
Thanks Phil, I'm guessing the up/down arrows would probably be fine on their own?
Mike
Mike
It would be nice to allow negative numbers in the nitrous page for users who want to use it in other ways, provided the code could accept say a negative fuel addition, or a negative timing retard.
1999 Dakota 5.9L R/T-
LC-1
LC-1
The actual mins and maxes are defined in the ini by the firmware developers.
