I have a 48MB log i'd like to load but i get a low memory warning despite having large memory enabled. Javaw process is using about 300MB, but I have over 3.5GB of ram free.
How can I increase the memory available to load and analyse the log?
Cheers,
Kristian
loading large logs, low memory
Constantly evolving;
4 cylinder n/a, 16v 1368cc Fiat Seicento
Re: loading large logs, low memory
48 MB, wow!
I will be increasing the memory allocation with large memory enabled. but you can give it more by starting with this bat file:
http://www.efianalytics.com/MegaLogView ... gFiles.zip
Unzip it and put it in your MegaLogViewer directory, by default;
c:\Program Files\MegaSquirt\MegaLogViewer\
Start the program with that and it will let you use up to a gig of ram.
I really do worry about you Do you you ever sleep
Worked a treat, thanks a load! I pressume i can adjust the parameters in the bat file if i ever load a bigger log
48MB is large, its about 2 hours of cruising, but i thought it can't harm to have such a long long for some fine analysis.
Thanks a million
Kristian
Thanks a million
Kristian
