changing pump prime
changing pump prime
is there any way to change the pump prime time to build up more pressure when using a low pressure pump?im using astock ford pump &i have to crank a few times before the pressure builds up.it starts than dies etc...for three or four times with a fuel pressure of 10 psi.after three tries its up to 20psi & idling.
62 f100,uni body,4.6 motor&updated chasis, ms2 micromodule
Re: changing pump prime
The issue here is not the tuning software but the code, as the pump priming time is not adjustable. You might be best off posting that in one of the code wish list threads.
i guess im just going to have to upgrade to a high flow/high pressure pump.
You could add a pump override push-switch that allows you to turn the pump on manually while the button is pressed.
or instead of cranking the engine , just shut the ignition on and off until you get pressure...
btw: There most be something wrong in your system. It should remain pressurized.
i only drive it or once a week or less,the pump is a 85 tbird pump that should be 14 psi.But i think think something is wrong with the pump .it wont keep 20 psi like it was & dips down to 10 psi,not good.well i was going to get a new pump sooner or later.PM me if u have any pumps ur running & like.thanks dan
