Tunerstudio changes com speed
Masi_K
Post by Masi_K »
It seems to that tunerstudio changes com port speed from windows according to tunerstudio settings. Unfortunately I can't test this again anytime soon. Has anyone faced this same prob too ? Laptop is IBM T20. No other external devices connected nor usb or other ports. Megatune doesn't do this. And somehow i can't create any project to the folder what studio propose. Maybe I should Uninstall/reinstall ?
WinXP SP3
LT401Vette
Re: Tunerstudio changes com speed
Post by LT401Vette »
I'm not sure what you mean... Do you mean the default port settings in the windows device manager?
I had not seen this happen, Is this causing any sort of problem?
It should be defaulting to [My Documents]\TunerStudioProjects\
You should always have write permissions there. You can browse to any other directory you like and it will create the project there too.
Masi_K
Post by Masi_K »
LT401Vette wrote:It seems to that tunerstudio changes com port speed from windows according to tunerstudio settings.
This is what I meant. This causes whole tuner studio program to run in slow motion. Menus drops down slow etc.
You should always have write permissions there. You can browse to any other directory you like and it will create the project there too.[/quote]
Yep, defaults to that location, but can't do anything to there in tunerstudio. In explorel theres no problem.
Masi_K
Post by Masi_K »
I tried to make it happend again with no luck.
Volvo 244 gle, b19e msns. R.I.P.
Vauxhall Viva, Msns. "Finally working"
Volvo 945 Turbo -97, Ms II. "There can't be more resistant install than this"
