I upgraded an MS1 running MSNs to Firmware rev 029y4, and I now get the following message when I open the project
"Failed to Subscribe DashComp to OutputChannel FIdle/Spark OnOC
Please Set to a Valid Output Channel"
The FIdle/Spark Label at the bottom of the screen is highlighted with a Red Border.
What do I have to change?
Message after FirmWare Upgrade
Re: Message after FirmWare Upgrade
I believe you need to enter the 'designer mode' and edit that gauge.
Ford 342 stroker | 4inj.TBI
MS2/Extra beta RC3 2.1.0 20090611
What happened is, apparently one of the indicators on your dash have been retired in the new firmware.
You can handle that a few ways:
Right click on the Indicator that has the red circle and cross through it, select a new "Indicator Template" that is valid for your new firmware.
or
Right click, select "Designer Mode" change the indicator, or just remove it from your dash by,
right click --> "Remove From Dash"
or
Right click --> "Load / Save" --> "Load Dashboard"
then select any of the dashboards in the dialog, those will be for your new firmware.
or
or
