logging data from 2nd WB O2 sensor?
Is the data from the second wideband O2 sensor in a dual WB setup logged somewhere? I could not find it in the datalogs.
Re: logging data from 2nd WB O2 sensor?
What firmware are you using?
I'm using alpha 20090313
It doesn't look like the MS2Extra ini has a data log entry for afr2 so you need to add one....
The best way is to create a file called
custom.ini
and place it in the projectCfg folder
the contents should be:
custom.ini
Code: Select all
[Datalog]
entry = afr2, "AFR2", float, "%.2f"
I'll give it a try, thanks.
