This thing runs linux, and I don't have the slightest clue what I'm doing here.
The other programs I've downloaded on this so far got installed through synaptic, but it won't recognize yours as an install package.
If I need to use the terminal to do this, I literally need a line by line walkthrough.
Installing Tunerstudio on an eee pc
Re: Installing Tunerstudio on an eee pc
I managed to get it un-tarballed and the path in the tunstudio.sh file set. it runs when i double click the .sh file.. I guess I need to figure out how to make a shortcut and all. gonna see if it will connect to the car..
edit:
n/m, gonna RMA this thing. Having hardware trouble.
edit:
Yep, you got it.
untar it, and run the bash script.
I will be putting together an installer package once out of beta. Just a little while longer.
