Its probably been mentioned on here before, if it has sorry.
Just done my first datalog using TS instead of Megatune and when viewing in MLV the highlighted load bins do not seem to follow the actual load that is logged.
For example 1.4bar abs seems to be highlighted in the 0.5bar bin.
The real time values are shown correctly as are the logged values, its just the highlighted bins.
Is there a setting I need to change in TS?
Datalog problem
Re: Datalog problem
This sounds more like a setting being off in MLV.
Post a short log and msq, that will help to see what you have going on.
Re: Datalog problem
Thought it might be a MLV setting.
It was the Y axis field being set to TP instead of MAP
Sorted now. Thanks.
Sorted now. Thanks.
Re: Datalog problem
good deal.
