I generally run on windows.
MLV has a nice "open" etc window that i can sort by date and view file properties.
TS is different, i can't view modified dates etc.
I guess TS is using a different API? If it's known, and intended due to programming nicetieis, then fair enough, but if the same window can be used in TS eastly, then that'd be nice
I can post pictures if you have no clue what i mean
Cheers,
Kristian
Open dialog windows. TS vs MLV
Constantly evolving;
4 cylinder n/a, 16v 1368cc Fiat Seicento
Re: Open dialog windows. TS vs MLV
I know just what you mean.... MLV has 2 different File Open dialog options.
I have gone into this on the MLV forum a couple times, but my biggest complaint with using Java for desktop applications is that the File Dialog option suck!
By default MLV uses the same basic file dialog that TS uses (but with a different skin), the Java swing dialog, but if you have "Use Alternate File Dialog" checked on the Options menu, it uses the standard Windows dialog that it always used in really old versions.
Here is the problem though, using the basic standard windows dialog, I have absolutely no programmatic control over it. All I can do is tell it to open and it pops up in the top right corner. I can't set filters, set placement, allow multiple selects... It really doesn't let me do much.
The other main stream option is the swing dialog, this give me very good control and has a lot of flexibility. Enough flexibility that in TS I make it look pretty much just like a standard windows dialog, But the down side is it is slow, has some bugs, and just doesn't have all the user features for file sorting that windows users are used to.
MLV you can still use the widows dialog with the only lost feature being lack of opening multiple files at once. But in TS I am pretty depended on being able to control the view as a project for example isn't a file but a folder structure.
I have dug into this and found quite a few complaints and bugs logged with Sun on the Swing file dialog, with some commitment to fixing them. The next best options are probably to write my own, which would probably be a longer term waste of time or look at another tool kit like swt, but then I would have additional dependencies and the distribution would grow....
So I am pretty much just at the mercy of Sun to fix the swing one... I hope.
wow, that is a difficult situation and a lot more complex than i had imagined.
Thank you for the in depth explanation.
It is not a big issue in any kind of way. The solution have have taken looks to be the best.
Lets hope Sun sort it out in the future.
Cheers,
Kristian
Cheers,
Kristian
Just had a further play, turning the alternative dialog off in MLV.
It still does what TS does not, ie. It diplays the modified date in the modified colomn, and you can click and it and sort by date. In TS, it just displays the file type in TS, and there is no modified date, or the ability to sort by them.
This is the pnly feature i miss with regard to the dialog boxes in TS, and it actually now just looks like a bug, as it works fine in MLV.
Shot at 2009-06-08
Shot at 2009-06-08
Is this part of the problem you described, or is just something that slipped through?
Cheers,
Kristian
Shot at 2009-06-08
Shot at 2009-06-08
Cheers,
Kristian
I'll have to see why the file type is coming up under date... There should be something I can do with that
Great stuff, cheers Phil
