Export import AFR
secco
Banned
Export import AFR
Post by secco »
If i export ny AFR Table only to save it then i try to import it i get following error
original AFR 14.7 after import i get 14.0 this happens with all numbers.
Behind the dot it write after the import a 0.
TS version 0.988.7
ciao Frank
Ciao Frank
RS2000 16V msextra GSlender 2.8 (better than OEM)
Re: Export import AFR
Post by LT401Vette »
Yes, that looks likem a problem. I'll look into it...
I should enable the table format, I hate the VEX format, it is pretty sloppy and very limited.
But it should work for that :)
msoultan
Post by msoultan »
Yeah, this is happening with the spark table as well. It was really throwing me for a loop - I was trying to build and export a table and I'd re-import it and all the zeros were dropped off. It drops off the decimal for both the values and the table indexes...
msoultan
Post by msoultan »
btw, the version I'm running is v0.988.7a
