Ecu will not go online
Mario
Post by Mario »
I couldn't get my computer to connect to the ecu all day? Pretty out of the blue and hasn't happened before. In the project menu it finds it just fine but in settings it hangs and will not allow me to go online.
1967 Beetle My test mule
The Dub Shop
Facebook
Megasquirt for life!
Re: Ecu will not go online
Post by LT401Vette »
Check your settings under the Communications menu, it looks like there no port assigned.
Mario
Post by Mario »
LT401Vette wrote:Check your settings under the Communications menu, it looks like there no port assigned.
Each time I try to assign a port (the one that it finds in project settings) it hangs and the little blue scroll bar just keeps going. And then I can't do anything else. I had to use megatune, AAhhhhh :lol:
The Dub Shop
Facebook
Ouch :)
Have you tried to create a new project?
If that does fix it, I would be very interested in seeing the project that isn't working. If you could zip the whole folder leaving out the log files, then send it to me, it would be much appreciated. p_tobin <at> yahoo. com
Mario
Post by Mario »
Well that did the trick! I'll send over the zip.
The Dub Shop
Facebook
Thanks for the zip, I see what happened. It looks like you may have changed the project folder, thus project name and it made it loose comm settings.
That is a bug, you should be able to change the project name / folder name. I have fixed that for the next release.
Mario
Post by Mario »
You're good. I did change the name, I added a space :) I almost changed it back but thought "no, that can't be why". Thanks.
The Dub Shop
Facebook
