Dear All,
I need a 16,000 rpm tacho in TS. I figured out how to achieve this in the main display but when I open the tuning display it shows an 8,000 rpm tacho. I expected it to use the same tacho as the main display but it obviously doesn't. Someone please tell me how to get a 16,000 rpm tacho in the tuning display. BTW, is there any documentation for Tuner Studio so I don't need to ask questions here?
Thanks in advance,
Dave.
Tachometer in Tuning Display
"In the beginning, the Universe was created. This made a lot of people
very unhappy, and was widely regarded as a bad idea."
HG2TG
HG2TG
Re: Tachometer in Tuning Display
You would change the Tuning Tach limits the same way as the main one.
Right Click on the tuning gauge cluster.
Select "Designer Mode"
Right Click on the Tach
on the right click menu select:
Properties --> Gauge Limits & Values
In the dialog you can change the min max, redline .....
I have on the todo list to come up with a way to make project wide limits for specific gauge types like RPM, AFR and temps. I just haven't gotten there yet.
TunerStudio Documentation still is pretty well missing. But it will come....
