Reference Table File
Eagle7
Post by Eagle7 »
Phil, I've added entries in the ms2ReferenceTables.ini file corresponding to my temp sensors and WBO2 settings. It works great, except it can get overwritten when TS updates. Is there another file I can put these settings into so they won't be overwritten?
Re: Reference Table File
Post by LT401Vette »
You could put them in the project ini itself. Take the whole block [MS2ReferenceTables] and all and add it to your ini, or better yet, create a custom.ini in the projectCfg folder and it will load them from there before the file in the [AppDir]\inc folder
But one better yet.. If they are good values, I can put them in file that goes out with the build and everyone can use them. If they aren't specialty, Send them this way :)
Eagle7
Post by Eagle7 »
I swear I tried this. :oops: Sure wish I'd tested it again before posting.
These are perhaps worth inclusion:
RX-7 S4 and S5 stock coolant sensor.
thermOption = "RX-7_CLT", 2490, -20, 16200, 20, 2500, 80, 300
RX-7 S5 air temp sensor in the air flow meter (not on the manifold)
thermOption = "RX-7_AFM", 2490, -20, 16200, 20, 2500, 80, 300
The other changes have to do with custom issues or adjusting the ground offset of my WBO2 sensor signal.
Thanks Phil. I love this software.
Marty
