Reference Table File
Phil, I've added entries in the ms2ReferenceTables.ini file corresponding to my temp sensors and WBO2 settings. It works great, except it can get overwritten when TS updates. Is there another file I can put these settings into so they won't be overwritten?
Re: Reference Table File
You could put them in the project ini itself. Take the whole block [MS2ReferenceTables] and all and add it to your ini, or better yet, create a custom.ini in the projectCfg folder and it will load them from there before the file in the [AppDir]\inc folder
But one better yet.. If they are good values, I can put them in file that goes out with the build and everyone can use them. If they aren't specialty, Send them this way
I swear I tried this. Sure wish I'd tested it again before posting.
These are perhaps worth inclusion:
RX-7 S4 and S5 stock coolant sensor.
thermOption = "RX-7_CLT", 2490, -20, 16200, 20, 2500, 80, 300
RX-7 S5 air temp sensor in the air flow meter (not on the manifold)
thermOption = "RX-7_AFM", 2490, -20, 16200, 20, 2500, 80, 300
The other changes have to do with custom issues or adjusting the ground offset of my WBO2 sensor signal.
Thanks Phil. I love this software.
Marty
Marty
